Control arm failure
  • #31
    probably a bit late since you already ordered parts but there are the ones i got there cheap and have a 10 year warentee with free shipping http://www.ebay.com/itm/151890535297...%3AMEBIDX%3AIT
    EDIT: well there not as cheap as when i bought them i only paid 35 for the set when i bough it still not to bad of a deal
    88 L carb'ed (when up in flames of glory)(deceased) 4spd
    89 L carb'ed (died on the operating table (rust))(deceased) 5spd
    93 gl FI (sold) automagical
    89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
    88 L carbFI megasquirted zombie car
    • #32
      For steering parts, I always get the best there is, in this case Moog. About the same price as everything else, and the tie-rod-end boots and lower control arm boots tend to last longest. Mine are all still fine after seven years.
      • #33
        Could turn into a can of worms. If all you really need is a tie rod end, stop right there.
        • #34
          Originally posted by chuyler View Post
          I ordered the tie rod just to be safe since they were cheap like you said, and I ordered the Haynes manual off their website for like $25.
          Does WD40 count as anti-sieze compound?
          And yeah if I can get it towed back to the school I'll just do it in the lot. A campus safety officer literally walked right by me while I was waiting for the tow-truck so I don't think they mind.
          @Festyboy
          Is this guy you by chance? I'm gonna send you a PM
          Hey chuyler, welcome to the Forum. The $5 that a small tube of anti-seize will cost you is money well spent. The WD 40 dries up rather quickly. As for using WD 40 for loosening rusty bolts it will help but you will get bettre results with something like PB Blaster. I see it on sale for as low as $4. I see you are in Pennsylvania so you will be glad you used it. Good luck bro.
          '88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
          '93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
          '91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
          • #35
            This whole thing has me scratching my head.
            Took car to 2 different places for alignment and neither one caught a potential problem with the ball joint?
            Inspector took the money and didn't right up anything? Including windshield and parking brake.
            Tow driver says AAA won't pay to tow back to campus? Call AAA!
            I hate to say it, but you've been snookered.
            • #36
              No worries, I got him covered.
              • #37
                He couldn't ask for better help.
                it is things like this that make me hate repair shops. They go out of their way to work people over. They see young people, or especially women, and the elderly as easy targets to make tons of cash off of. Weekly, I see this.
                • #38
                  Yes, and I'm glad he is.
                  • #39
                    5/1 UPDATE:
                    The car is back on the road! Festyboy came over early this morning and we knocked it out in under an hour. Also got Wendy's and bought some tools, so pretty good day overall.
                    Thanks for everything Arthur!
                    p.s Here's a picture of my ford next to another much larger ford.
                    • #40
                      Awesome!
                      Rick
                      1993 Ford Festiva
                      1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
                      1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
                      2000 Ford E350
                      • #41
                        What all did you guys do to it?
                        • #42
                          The only thing that was needed surprisingly: control arm. Then we filled the trans. Quick easy job. The axle was in good shape, as was the axle seal. Tie rod was tight and the strut still good and straight.
                          • #43
                            That was really nice of you Festyboy!
                            • #44
                              I drove to class tonight and noticed a faint grinding sound coming from under the left drivers side (the damaged area).
                              Any ideas what that could be from?
                              • #45
                                Hard to say. I'd suggest jacking up that side with the car out of gear and rotating the tire by hand to see if you can locate it. For safety I'd put a block under the car and not rely on the jack alone. Other things to try are listening while going slowly in a tight turn in a parking lot forward and backward suggesting worn CV (universal) joint in the axle, and swerving right to left while driving suggesting wheel bearings. Also with the car sitting on the ground push and pull on the top of the tire to see if there is any movement suggesting worn wheel bearings.
