Is there any step by steps on how to check ring seals. I just put a new motor in but it wont start. Wife wants to kill me already because the car isnt working. So money is some what tight. Any help appreciated.
Ring Seals
Compression test is how you would check the rings. What's it doing when you try to start it? Are you sure you have the ignition timing correct? When you say new motor, is it a brand new engine, rebuilt, used engine from another vehicle?Rick
1993 Ford Festiva
2000 Ford E350
Compression test. Or if you're ok to spend a little more, leak down test.
First thing to check is your mechanical timingTrees aren't kind to me...
Timing is good i am tdc on everything and i just did a compression test 1 has 0, 2 has 30, 3 has 15, and 4 has 30. And the motor is from another vehicle. Also it keeps backfiring out of cylinder 4.Originally posted by Eaglefreek View PostCompression test is how you would check the rings. What's it doing when you try to start it? Are you sure you have the ignition timing correct? When you say new motor, is it a brand new engine, rebuilt, used engine from another vehicle?
It will not run with those compression numbers.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
Those numbers are so low I would try another compression gauge. Another possibility are valves that are either bent or sticking open. Even if the rings are worn you will have some compression.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
Try pulling the spark plugs and squirt a little oil down into the cylinder. By a little, about 2 ounces. Put the plugs back in and check the compression again. If the numbers come up substantially you have bad rings. If there is no change it sounds like a valve problem. Did you check the timing belt to see that the camshaft is turning?'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
They should be well over 100 psi but I have seen engines run with as low as 60 psi. Your engine won't run at the numbers you posted.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
Ok and yes i have the timing cover off at the moment.Originally posted by Rick the Quick View PostTry pulling the spark plugs and squirt a little oil down into the cylinder. By a little, about 2 ounces. Put the plugs back in and check the compression again. If the numbers come up substantially you have bad rings. If there is no change it sounds like a valve problem. Did you check the timing belt to see that the camshaft is turning?
I never checked compression on an engine with a broken timing belt but I am thinking that would be my next check. If you pull the distributor cap and crank the engine you should see the distributor turn. Before you crank it over, unplug the wire going to the center terminal of the distributor cap and ground it while you are cranking it. This protects your coil.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
I'm jealous of you seal level people. At over a mile high where I live the numbers are a lot lower.Originally posted by ryanprins13 View PostCompression numbers should be 140-190psi.
Sounds like something else is wrong
Sent from my SM-G920W8 using Tapatalk'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
