Originally posted by alena
You might want to change the timing belt just because its old. However these are non-interference engines and should be fine if that does break.
More photos would be cool
The electronics and sensors are pretty basic on the festiva which is nice, but they are still there. The electronics inside the distributor which control the coil are a little beyond my understanding and the air temperature sensor is in the same unit as the VAF which annoyed me years ago. But all in all very basic and easy to learn.
The steering isnt too bad as long as your moving. However if it annoys you there is a fix for like $50 plus a wheel alignment to make the steering easier than some cars with power steering. The difference really is amazing but you have to be able to make some sort of customized part yourself. If your interested i can find where it was in my build thread.
With the e-brake siezing on most cars its the cable thats the problem. They can sieze up on festivas too, but more commonly it is the self adjusting mechanism inside the drum. It has 2 pivots which sieze and cause your parking brake to stick and the rear brakes to not work properly.
I had that issue for 8 years and whenever i did have to use the parking brake after releasing the lever inside the car i would reach around behind the front of the back tire and pull the cable towards myself which would release my brake. If you search siezed parking brake on the forum here you should find some more detailed info on fixing it. Replacing the self adjusters is by far the best bet but new ones are very pricy when they become available and it takes a while to find a good used set unless another member from arizona wants to ship you a set.
With the rust have a good look at where the rear axle mounts to the frame of the car. Thats the only super important part to check for rust. For the rest just buy a couple cans of fluid film or similar wax oil/rust preventer oil and spray everything. That will slow the rust down.
I worked in autobody for years and rust is never cost effective to fix on a car like this. Unless you want to learn bodywork but there are better and more rewarding ways to learn... i think your better off to use fluid film once a year on everything and save up for another shell 8 years from now and just swap your good stuff from this car into it at that point.
it's small enough for me to work on myself, I have all the tools but I've never been able to strong arm anything on my other car, a luxury trim 2003 AWD Mountaineer, it also has so many electrical things and computer sensors, that's way too complicated for me so I always sent it to someone who has experience with complicated cars like that. This festiva has basically nothing complicated about it Computer and sensor wise xD and it's lightweight enough that I can move parts on it myself. I'm just a small 5'5" at 135 lbs and not much muscle lol, but I know I'll be putting more on my arms pulling my festiva steering wheel around all summer without the power steering I'm used to! I took an auto class in high school and helped my dad fix lots of different cars, but I'm hoping to learn how to do everything with this festiva myself. :>
