I have an 88 model festiva. Just bought it. Had been sitting a couple years. Needed a head, took head off running 93 efi car. (Casting # was same). The car ran fine for 4-5 hrs, was looking the car over and noticed the coil was puking oil out where the coil wire goes. Replaced coil with an msd blaster 2 coil i had. Started the car, it ran about 10 seconds and died.
No fire.. tried a brand new coil.. no fire. Im getting an occasional weak fire with my spark tester but the car will not hit. The pulse and voltage read as they should with volt meter. Im about to pull my hair out!!! I would buy a reman dist. If i knew it would fix it. But im not sure since im getting a pulse to the coil from the dist.
Any help would be appreciated.
