What sending units have you guys used that operated the factory gauges reasonably well? Anyone know the diameter and thread pitch on a factory festy sender?Thanks
Temperature sender,engine swap senders etc. Questions
30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.Tags: None
M10 x 0.8 iirc, it's an odd one for sure.Trees aren't kind to me...
Thanks, do you know of any other senders that give a reasonably accurate reading on the festy gauge? I actually am trying to mount a sender that will work a mazda gauge in a b2000 intake manifold the hole I am working with is 1/4 npt which my thinking is thread the inside of a brass 1/4 npt pipe nipple to use as na adapter bushing for a festy sender but if someone knows something 1/4 npt or close, that would be even easier. gotta be done by noon tomorrow and got other x@#s@4 to finish on the truck still so just looking for stupid simple reasonably functional.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
