Temperature sender,engine swap senders etc. Questions
  • Temperature sender,engine swap senders etc. Questions
    What sending units have you guys used that operated the factory gauges reasonably well? Anyone know the diameter and thread pitch on a factory festy sender?Thanks
    M10 x 0.8 iirc, it's an odd one for sure.
      Thanks, do you know of any other senders that give a reasonably accurate reading on the festy gauge? I actually am trying to mount a sender that will work a mazda gauge in a b2000 intake manifold the hole I am working with is 1/4 npt which my thinking is thread the inside of a brass 1/4 npt pipe nipple to use as na adapter bushing for a festy sender but if someone knows something 1/4 npt or close, that would be even easier. gotta be done by noon tomorrow and got other x@#s@4 to finish on the truck still so just looking for stupid simple reasonably functional.
