I have a junker 91 festiva that I can't get to start up. I squirt fuel into the throttle body and it runs on those fumes great but then dies. I'm pretty sure its the fuel pump. Previous owner said it had something to do with the steering wheel...? The steering wheel is off, the ignition switch cut into (start it with a flathead screwdriver), and none of the connections at the steering wheel are hooked up. Lights come on and fan comes on when turning the key (screwdriver :-P) Any tips on how to see if the fuel pump is working and/or get it to work? P.S. I know something to do with the relay might be it but I'm confused as to wether the relay needs to be changed or what....
Thanks!
Thanks!
