Originally posted by jjaynes
It's a t shaped black connector it's over by the break booster. Just get a paper clip and stick it from one side to the other. Then turn on key. Or just as easy. Pop the single spade wire off the starter to disable it and turn the key all the way as if your starting the car. The stater won't turn because of the wire you removed but it will trigger the pump for as long as the key is held in the start position
