Need help cant figure out how to remove the ignition from the stirring column please help
91 Festiva Ignition Removal .... problem getting the Ignition off of the Column
You need to notch the snap screws or use a cold chisel to get them loose then needle nose pliers will do the rest.Trees aren't kind to me...
I used a small cut off wheel on my air grinder. I took off the plastic around the dash so i didnt cut it up. I ground a small notch then used a screw driver to back the srews out. Good thing is that once you get them to turn just a bit they come right out.
I never had a key issue on any festiva and then out of nowhere i had 2 different cars fail in the same week.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
