Title says most, I'm getting ready to replace the clutch in my 92, I knew the shifter was sloppy but holy cow, every bit of the linkage is loose. there is a pivot under the shifter itself, and a vertical and horizontal pivot at the transmission, one has a bolt going through it, the other is just a pin. Is there a known fix for this?
Thanks for any advice.
5 Speed, 244,000mi and counting!
