So I have a suspension related noise when driving. It sounds kind of like if you had a broken sway bar end link but not quite that bad.
I'm not familiar with the rear suspension but it looks a bit different from cars I'm used to. Can you suggest the most common parts that may cause a knocking noise over bumps? It seems to be coming from the right rear area.
I already checked and removed everything from the trunk so it's not junk rattling around inside the back.
