It's been a while since I've posted here. Been busy and side-tracked, I suppose.
Swapped in a B8 in my '93 about a two months ago. Has run fantastic until last night. I was cruising about 65 in 5th and all of a sudden acceleration stopped and it felt like I was out of gas (1/2 tank - confirmed). I pulled off and checked all over for vacuum/intake leaks. Couldn't find anything. Got back in and she fired right up no problem, so I headed back out. I got about 2 miles to a hill, and barely made it to the top. It'd start and idle, but not move without stalling out. Ended up having her towed the last 20 miles.
Today from parts I had waiting to be installed:
New fuel pump
New fuel pump sock
New fuel filter (not stock Festiva - but same size inlet and outlet from an FI car)
New coil
After the pump it fired right up.... then died completely after I tried to move it. Now it just turns over and allllmooost catches, but won't start.
Pump is working.
Reset inertia switch though it was fine.
No intake leaks that I can find.
Tapped on injectors lightly, didn't help.
What else is there.. bad gas? Air in fuel lines?
Thanks.
Joe
New fuel pump
New fuel pump sock
New coil
Pump is working.
Thanks.
Joe
In the 1.5k miles I've put on, I've been averaging about 34MPG. Likely because winter gas and I haven't taken it on too much highway yet (and I've been a bit hard on it). I'm hoping for atleast 37-40 on long hauls.
