What would cause the shift lock to intermitadly work? You can cleanly hear it clicking but 50% of the time you fool with it for 5 minutes jabbing the brake and wiggleng the shifter and wind up getting pissed and just overriding it with the manual unlock slider. Not sure if it matters the bulbs may be bad but the reverse lights don’t work either.
Shift Lock Issue
For the shift lock servo assembly, pull apart connector C305 (in the console between the drivers and the passengers seat) and check to make sure there is no corrosion on any of the terminals.
Also check to ensure ground G300 (under driver's seat) is clean and makes good contact.
I would check the ground first. A lot easier if you remove the seat. Please post a picture.Last edited by bravekozak; 12-29-2017, 11:04 AM.
