91 Festiva GL, 5spd
Often, while driving at the same speed on the highway, the power will drop off slightly and the check engine light will come on. I'll give it a little more gas, and it'll bog further. Then, I'll let off the gas, and stomp the pedal through it's full range a few times. When I do this, the power comes back, and the engine light will go out. I'm inclined to think this is the throttle position sensor acting up. Before I shell out 60 or so dollars on a new one, does anyone have any thoughts?
