So I have changed the cooling fan switch, and the changed the thermostat. (one from oreillys) I did the proper procedures. The coolant temp gauge doesn't seem to go up to the middle like most cars. The fan turns on when the coolant temp is 1/3 way up. Is this common? How often does your fan turn on?
Cooling fan working too often
The Festiva gauge can be really inaccurate. Try using a infra-red thermometer or similar to get an actual temp reading.Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
Welcome to the forum!
Temp gauges vary car to car and aftermarket thermostats like stant vary very widely on opening temps even if they all say 192 or 195f.
Was the switch not working at all before?
Whats the part number and brand of the switch you used?
Fan is supposed to turn on at 207f iirc.
On my car that is a little higher than i made the red mark in this photo.
Also fyi ir guns are calibrated on a flat surface painted flat black. They vary based on quality but typically do not get an accirite reading on curved surfaces. Impossible to get a true reading with mine on round pipe or hose
Originally posted by ryanprins13 View PostImpossible to get a true reading with mine on round pipe or hose
Better than an unmarked gauge from a 25 year old sensor?
Quite possibly, lolWill Samet
How to find me:
Quite possibly, lol
The emissivness of different parts of the engine is all over the map. Many spots arent .9-.95 like most ir guns are calibrated to, the curves mess with it and its very tempting to take readings up close which throws it off. At a proper distance most ir guns are reading a wider area than you want to on the engine and on and on.
Ive tried with mine and yes you can get a true reading in particular spots but you need to have the temp verified by something else first.
Its not little variations, im talking like 50 degrees F difference between spots that are actually within like 5f of eachother... i found it a real pain trying to get readings off my b3 with this.
Originally posted by TimKuz View PostSo I have changed the cooling fan switch, and the changed the thermostat. (one from oreillys) I did the proper procedures. The coolant temp gauge doesn't seem to go up to the middle like most cars. The fan turns on when the coolant temp is 1/3 way up. Is this common? How often does your fan turn on?
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 01-16-2018, 06:55 PM.
The EVTM is wrong about which switch and wire color it is.
As you can see in the diagram, the cooling fan switch serves as a ground for the relay.
Make sure that you don't put any Teflon tape or other non-conducting sealant on the threads of the switch.Last edited by bravekozak; 01-16-2018, 07:22 PM.
Originally posted by bravekozak View PostThe cooling fan temperature switch is the little switch in the cylinder head.
Sent from my SM-N910C using TapatalkWill Samet
How to find me:
It seems like the thermostat opens before the fan comes on, but it seems like not much time passes by and the fan turns on. If the thermostat is actually opening up at 190, technicallly, 207 isnt that far up ahead. I'm just trying to figure out if it's a common thing that the fan works so often. If it works during the winter rarely, imagine how much it will work during the summer. The fan switch part number is TS113
If the fan is still being erratic after you replaced the fan switch it's probably still the switch. Those aftermarket switches are pretty hit and miss on if they work correctly. This the part number for a oem mazda switch. They cost a little more but they work.
Sent from my SCH-I545 using TapatalkBetter Than Nothing Racing
Way too many cars
:woc:
Even with a Mazda dual stage thermostat, mine runs on the cold side. My fan rarely comes on even in the summer. Just when I have the AC on or if I'm stopped for a long time in a drive thru. If your car is running at the right temp, I wouldn't worry about it too much.Rick
1993 Ford Festiva
2000 Ford E350
