Anybody know how many bolts the injectors fire at? Trying to rig up something
Fixed fuel pump and now...
I recently worked on a BMW K1000 motorcycle that had been sitting for a few years. Along with replacing the frozen electric fuel pump I sent the injectors to Mr.Injection in Idaho for a proper cleaning. He charges $17.50 per injector and provides you with a before and after flow results. Also on my particular application included new O-rings at no additional cost. According to my research the O-ring on the K1100 BMW/Bosch injector is a dealer only item at $8.00 each. The free O-rings were definitely a deal sweetener. The best part was installing them and hitting the starter button and finding the engine ran perfect. I just talked myself into sending my spare set of injectors to him for cleaning.....Good luck!
Last edited by Rick the Quick; 04-02-2018, 10:22 AM.'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
'93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
'91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
I just used 12 volts on mine and they still worked afterwards... Mine sat so long that the needles were actually stuck. I took the cap off of them filled them with carb cleaner and tapped the needle on my vice a few times and then applied a 12 volt pulse to make sure they were opening."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
That is great information on the o ring hack. Fortunately I live in Southern California where I can find a shop I can drive to on the way to work to drop off injectors. Unfortunately OP is still troubleshooting, hate him to blow money on something that "probably" is the problem. OP needs a local festy buddy who can swap vams and eliminate that one. I have 2 complete festiva rails with injectors on them still, but they've been sitting on shelf for years so they'd introduce a problem if they were blindly installed in a running car.
The wiring PDF might have the voltage and restistance for the injectors if they are not 12v. The important part is the resistance. Using that crude battery cleaning method you are tapping it hot quickly so it shouldn't fry windings and electronics in them.
Sent from my Nexus 6P using Tapatalk1993 GL 5 speed
Just Checked the PDFOriginally posted by getnpsi View PostThat is great information on the o ring hack. Fortunately I live in Southern California where I can find a shop I can drive to on the way to work to drop off injectors. Unfortunately OP is still troubleshooting, hate him to blow money on something that "probably" is the problem. OP needs a local festy buddy who can swap vams and eliminate that one. I have 2 complete festiva rails with injectors on them still, but they've been sitting on shelf for years so they'd introduce a problem if they were blindly installed in a running car.
Voltage Resistance for Injectors are 12-16 ohms"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
I just read further down in the PDF Shop Manual and it says to check for 12v at the connector."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
I think the injectors are the problem. They won't squirt right at all. Just dripping. Im gonna try another rig to get carb cleaner through them. Do you have to have a good bit of pressure for them to open? one injector just clicks when I give it 12 volts.'93 Festiva L "Blue Beauty"
'91 Festiva L (Red, parts car, future project)
'90 Festiva L (Junker, Red)
'98 Explorer XLT "Exploder"
I did mine with no pressure. I just filled them with Carb Cleaner and then hand pulsed 12v and watch the liquid leak out. They might clean better under pressure but it is not required for them to open.
If they aren't opening them at all try taking the cap off and tapping the needle against a hard surface to see if you can get it to depress and break free. It worked for me.Last edited by firebush357; 04-02-2018, 01:30 PM."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Yeah, gently squeeze it with a pair of pliers or a vice and pull it off.Originally posted by jjaynes View Post“Cap” is that the orange end that squirts?"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Update:
Cleaned injectors, they are running clean. Hooked it all back up and: nothing. Pulled the fuel line off and cranked, the fuel is just kinda running out. Not a lot of pressure at all. Should the fuel be really squirting out of the line or is normal for it to kinda easily flow out? Not sure where to go from here; starting to get worried this car may never run.
Also:
Why is it that there doesn’t seem to be a change in gas flow when the gas is pressed? I’m not clear on how all this works but I thought gas pedal meant more fuel (and air of course)?Last edited by jjaynes; 04-07-2018, 04:01 PM.'93 Festiva L "Blue Beauty"
That fuel should be shooting out under high pressure.
Either your fuel pump doesn't pump, or it's not wired up correctly, or you have a blockage.
Pull the fuel pump back out and test it.
It should sound like the first sound in this mp3.Last edited by bravekozak; 04-07-2018, 07:20 PM.
Alright so I have an idea that it might be low voltage to the pump. On the voltmeter it registered like a 6 or 7 maybe? I don't remember but I KNOW it wasn't 12V. Why would this be? Note that there is no battery in the car, I run jumpers to the cables from another car to get it to crank. Battery size is always Festiva size or bigger from the running car though.'93 Festiva L "Blue Beauty"
