Anyone know of an easy way to remove the Inner tie rod locknut Pin, that little pin that keeps the inner tie rod from unscrewing? Ford has a special tool that looks like a miniature slide hammer, put the parts stores don't carry anything like that.
Inner Tie Rod removal
Just unscrew the rod end. The pin will slide out slightly to clear the threads by itself.BP powered 91 Festiva L
-FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
-Trunk mounted gel battery
-Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
-Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
You can put a pipe wrench on the inner tie rod and just turn it. The pin will pop up by itself. I was told to use a pipe wrench by a few steering rack rebuilders. It worked like a charm.90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
