Alignment
  • Alignment
    My front right is shaking alot. When i push on it the tie rod moves upwards a bit and feels loose. Do i just need to tighten it? Shakes alit between 55 and 65 mph. Thanks
    Sent from my LM-X210(G) using Tapatalk
    The bottom nut should be held in place by a cotter pin. Has it gone missing? The shaft won't turn unless the bottom nut is removed and the assembly disconnected from the knuckle. If the ball joint feels loose it's probably worn and needs replacing. They don't cost much and if the thread on the shaft isn't rusted and seized they are easy to replace DIY.
    P.S. You could try swapping the front tires right to left to see if the shake in due to the tire.
      Ball joint isnt what is loose. Where the tie rod end conects to the reat of the shaft
        One sec ill take pics
          Where the rubber piece is feela loose bout 1cm of play
            Ball joint on left side def shot to hell though
              Either the inner tie rod is loose or worn out and needs replaced. One other thing it could be the rack bushings are worn out if the point is moving up/down
              Jerry
              Team Lightning
              Owner of Team Lightning
              93 L Lightning. BP
                Awsome. Plan on putting a set of old ford falcon wheels on it next week
                  With trim rings and baby moons??? I love that old school stuff!
                    Idk what that is but thay are just steel boring wheels. The highway speed is 75. We all drive 90 so i need wider tires. Pick and pull charging me 84 for the whole set
                      Ye old hooligan
                        The worn ball joint on the lca could be causing some shake, but you wont know untill you fit the other side.
                        Is it the blue or red circled part thats loose? Or can you feel movement in both? Once one starts vibrating that hard it wears the other pretty quick.
                        You need wider tires to drive faster? What size do you have now?
                          ^^ that lca looks pretty new. not even any road dirt on it.
                            4 inch tires now unstable at 75
                              The red parts moves up a bit
