4 inch tires???
Ok, like everyone said, you either need a new steering rack bushing or inner tie rod end. Before you order the inner tie rod end check the boot. If its cracked or has holes get a new one of those too. If water gets in there it will wreck the new tie rod end soon and you dont want that.
You could try these rims. They take around a 405-460mm wide tire.
