My 95 aspire se ,shut off while driving, no warning,tried restarting kinda wanted to but no go . Towed it home ,I got no spark ,no fuel coming out off fuel line from the outlet side of the fuel filter . Any suggestions on what to check on next ?
95 aspire se , cut off
No spark AND no fuel? How did you determine no spark?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Does the fuel pump make any sound? If not sounds like no electrical power to ignition system or fuel system. I'd start with the battery and fuses. If the battery went dead perhaps the alternator stopped generating electricity. Simple to test for dead battery by turning on lights or something.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Engine fuse, black/white stripe wire, for the engine control system and the charging system.
Remove the steering column cover and check if the wires aren't fried. Check your main relay.
Check your alternator to see if your regulator is fried.Last edited by bravekozak; 05-19-2018, 04:27 PM.
Sounds like a short circuit somewhere. Has any of the wiring been replaced or tampered with? That also might be a good place to start checking.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
