my battery light came on and my engine is running hot. any ides? it just happened today.
help?
ok serisouly people need to read the rules first, A DESCRIPTIVE NAME and list your car year, engine type (efi or carb) ac, manual or automatic etc how freakin hard is this2007 Ford Taurus 23-25MPG
1976 Chevy Silverado (my toy)
http://www.aintperfect.com/
woodson
Newbie
Posted: Mon Oct 30, 2006 5:04 pm Post subject: help?
93 L
Battery light and overheat at the same time , Is the belt still on it ??------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Don't drive it till you check the belt.
sorry, kinda new. 93, 5 spd. efi. 136000 miles. was running fine till today. the battery light came on. then the temp went up near the top. the idle is also higher than normal. any ideas.I have owned 15 nissan/datsun's and 1 ford. What the hell is the matter with me?
93 L
uh.....ya. my belt is missing. it must have come off on my 50 mile drive through the canyons yesterday. how lucky am i that i made it home without destroying the car? is that an easy fix?I have owned 15 nissan/datsun's and 1 ford. What the hell is the matter with me?
93 L
You are very lucky !!! that you did not cook the engine------------------------------------------------
Z28 LS1 power 500 +
"is that an easy fix?"
Its easier if you don't have A/C. Just loosen the adjustment bolt and also the mounting bolt ( little hard to get to ) on the generator and slide the belt on . Adjust the belt tension with a pry bar against the generator and re tighten both adjustment and mounting bolts. You will see once you look at it. Piece of cake.sigpic
