If you are really worried run a compression test. All cylinders within 15% high to low no worries.1 or 2 real low get a fitting to blow compressed air into the offending cylinders rotate and lock the engine so that both valve are closed on the cylinder you are testing,blow in compressed air if air is escaping anywhere, out the exaust,through the intake, through the oil filler or bubbles in the radiator,let us know so we can direct you further.
Originally posted by imnotjohnpaul
