The hose that I see looks like factory and the tensioner is the same as mine.
To be sure you need to take a picture of the compressor where the hoses connect to the manifold.
Do you plan to use R12 or 134a refrigerant?
Since your system has been open for a while you will need to remove all the components and flush them thoroughly.
You will also need a new expansion valve (about $15) and and new receiver/dryer. ($20 to $25), plus all new o rings for the connections.
How often do you AC in Alaska anyway? I see you note & Seattle, shipping would be a lot less to Seattle.
Seems like a daunting job if you have never taken a system apart before but it really isn't.
