Hi, I am pretty new to working on my car. I have a 1990 festiva with a manual transmission. It came with automatic seatbelts which worked at the time. However bit by bit the drivers side belt wouldn't go back. it wold go back if you re-opened the door and closed it very firmly. then a week or so into that it stopped completely and wouldn't go up. Then a day later on my way to work I hit a pot hole and it went back. problem fixed., but it has stopped working again. Any how I picked up a haynes manual today to get some info wiring diagrams and all, but suprise suprise once I got the shrink wrap off the manual there wasn;t any info on the seatbelts at all.
could anyone tell me the best starting point to fix the problem? I tried searching here on the forum, but had trouble understanding the info. I am kind of thinkoing that maybe there is a grounding issue, cause a couple of times I have felt a slight shock when I touch a metal part on the door, not much more than static feeling, but maybe. any how where shoudl I start? I'l get the door panel off tomorrow morning and see if I can see anything. any ideas of where to go from there will be greatly apreciated.
chris
chris
