First thing to do is label EVERYTHING !
Get a roll of masking tape and a Sharpy marker, label every connector and hose.
Label both parts, if its an electrical plug, label both plugs.
If its a hose, label the end of the hose and the part you pull it from.
I used numbers on the hoses and letters for the electrical stuff.
Then when you put it all back together all you have to do is match up the numbers.
It will take you a while (30 mins or more) to do them all but it will save you that much time and headache when you are putting it all back together.
When I have taken my engine out, I pulled the trans too. I don't see how you get it out without doing that.
I also dropped mine out the bottom.
