changing rear springs????
  • changing rear springs????
    back a while ago, i notice my rear spring had broke, i finally got another one from a junkyard, (the car was wrecked when it was a year or two old with like 60k miles on it so it almost still looks brand new) but anyway enough rambling, my question is do i need a spring compresser for the rear springs so i know if i can change it myself or not?
    i've had the rear struts off of my other car but didn't take the spring off of the strut but for some reason i'm thinking when the strut gets bolted to the car, thats when it compresses the spring, but i'm not sure, can't remember that far back
    it is not your typical strut
    first thing you do is to remove the 2 interior pieces ( the rear speaker shelf and the piece below it)
    then remove the single strut on each side
    THEN JACK UP THE REAR OF THE FESTIVA
    the struts and springs will disengage the car's top strut mount and the rubber isolator will sometimes fall out too
    then remove the lower strut to suspension assembly
    and remove the strut and spring assembly as two separate pieces
    installation is the exact reverse
      awesome, thanks, exactly what i needed to know
