Alternator putting out 39 amps
  • Alternator putting out 39 amps
    Is this normal for an FI Festiva? I was driving to work this morning and my charging light flickered a few times then came on steady. I took the battery and got her charged but it came back bad so I put a new one in. With my new battery in the dummy light doesn't come on but the Alternator is showing 39 amps at the battery.
    Also I found in this post http://www.fordfestiva.com/forum/vie...ght=alternator , this list of alternators and amperages:
    Capri - 70amps
    Escort GT/Protege - 65amps
    626/Probe/MX6 -80amps
    Will the 626/Probe/MX6 alternator plug in or is splicing needed?
    Thanks,
    Primo
    the alternator is full fielding
    it is time to replace it before it boils your battery to death
      I did a quick google search it looks like full Fielding just means my regulator is bad?
      Thanks again,
      Primo
        it is an internal regulator
        you can replace it if you don't mind the tear-down
          Not really looking to try to replace it was just expanding my knowledge of automotive terms
          Primo
          P.S. Did you see my edit to ask a question about alternators up top? Any insight to offer?
            i've found the 87-89 Mazda 323 had 60 amp alternators
            just depends on any aftermarket equipment you've added on
              i had a pinto when the alternator went bad it made my battery bulge it sides and the battery was hot.
                so what alternator will swap right in without modification?!? or if minor mods are to be made, please list them also.
                1992 Festiva
                2002 Jetta 1.8T
                  how about a new one, I hear they go right in easy, and will last you almost as long as the car :-)
                  Just pull one out of another festiva, or aspire, if your looking for a cheap quick fix
