what's the best/easiest way to replace the front bearings on a '91 Festiva L with a 5 speed?
Wheel bearings
Wheel bearings
5 Festys and counting!!
1993 GL auto 126,000mi
1991 red 5-speed B6T G25 swap in progress 255,000mi
1990 white 5-speed/Aspire swap daily driver 273,000 mi.
1989 silver 4-speed parts car
1989 white auto El Festivo
1992 Chevy Silverado K1500 soon to have 383 stroker
1999 Mercury Sable
1992 Pontiac Bonneville SSEi Supercharged For SaleTags: None
Re: Wheel bearings
Originally posted by zrice88what's the best/easiest way to replace the front bearings on a '91 Festiva L with a 5 speed?
cant i just do it my self? i work in a garage and have access to a press. won't i need an alignment after that?5 Festys and counting!!
1999 Mercury Sable
Originally posted by zrice88cant i just do it my self? i work in a garage and have access to a press. won't i need an alignment after that?You gonna race that thing?
thanx for clearing that up for me5 Festys and counting!!
1999 Mercury Sable
wheel bearings
You can't just replace the wheel bearings. You have to also install the correct shim for the bearings. There are at least 10 possible shims. You can try using the existing shim as I did once but that ended up ruining new bearings. You can get the shims you need from a Mazda dealer. The 323 used the same shim. Getting the jig to do the calculation to determine the correct shim is more complicated. The simple solution would probably be to take your parts to a Mazda dealer and have them calculate the shim needed. You can probably save some money if you take them the parts sans the car.
My alignment went bad the last time I replaced a front bearing. I didn't know about the shim.
A really good mechanic did the job for me on a major press but he said nothing about the shim.
Our parts store machine shop couldn't get it to give so the truck shop mechanic got it with his big press, I was surprised, I will never try one myself again.
Why do you need a shim? i've never heard that i need a shim. my dad and i have replaced the bearings on his '89 and never knew or heard or used any shims. what are they for?
also, how do i remove the hub/rotor assembly from the drive shaft w/o ruining them?5 Festys and counting!!
1999 Mercury Sable
once you remove the nut for the axle shaft, just tap it with a hammer, comes out easily. Took mine in to get it done, cost $150 with new bearing and rotors. PITA job.69 Shelby GT-350, 351W, 4 spd
97 Jag xk8 vert
06 Mini Cooper S GP
93 Stiva
04 Volvo S80
The shim adjusts how tight the bearing and race are in each bearing set. When you tighten the hub and knuckle together, you are tightening the bearing too. I've never seen a hub without a shim, but I guess it could be possible that your dad's car worked without one. The shim is a thin washer that goes between the 2 bearings to stop them from being too tight when you press the hub and knuckle together. If you are familiar with the rear wheel bearings, you wouldn't torque the spindle nut to 100 lbs. because the bearing would be too tight. This is what would happen with no shim in the front hub. Likewise, you wouldn't tighten the rear wheel spindle finger tight because it would be too loose. A too thick shim in the front hub would keep the bearings loose. Whenever I replace bearings, I use good quality bearings and I have never had to change shims to a different thickness. After I press it together, I try turning it by hand. I've done enough wheel bearings that I can pretty much tell by the "feel" if the bearings are too tight or too loose.
To remove the axle, try holding the hub assembly while someone holds a block of hardwood on the end of the shaft and hits it with a hammer. If it still won't come out, you can use a gear puller attached to the lug bolt holes and press on the axle. I am assuming you took the axle nut off first.You gonna race that thing?
where could i take it to have somebody else do it? i already bought all the bearings and seals. what can i expect to pay?5 Festys and counting!!
1999 Mercury Sable
If you have any experience working on vehicles, you can do this yourself. Nothing all that difficult about it. Festy 46 summed up the shim well.
Whether or not you need a different shim just depends on how the new bearings seat into the housing. My dad just replaced his the other day and he used the stock shim and the preload was fine.
When I did mine several years back, once the new bearings were in, I could hardly turn the wheel by hand, so I made a couple shims and placed it in with the stock shim until the preload was correct.
If you take it in to a mechanic to fix it and start talking about preload spacers, they may look at you kind of funny. The Festiva front wheel bearing assembly is kind of a rare bird, and many mechanics have never replaced bearings with this type of setup.
If you have a press, then just try it out yourself. If you have to take it apart again, you may need to buy a new inner seal, but can probably save the bearing if you are careful. Don't lose the spacer!BP powered 91 Festiva L
-FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
-Trunk mounted gel battery
-Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
-Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
