95 Aspire/5 speed. Turns over great and will start with gas down the intake, the previous owner had that bright idea. I have 12+ volts to the fuel pump relay but no 12+ volts to the fuel pump. I can jumper it and get 12+ to the pump. Even with 12+ to the pump no gas even though I can hear it kick on. I'm going to pull the fuel pump to make sure the screen isn't clogged but to me it sounds like the fuel pump and relay are toast. What do you guys think? This is the first time i've had to mess with a fuel system on a Festiva/Aspire.
Got no fuel..
Normally the pump only comes on when the engine is cranked , If you put 12 volts to ,it and you still have no fuel , I would say the pump is toasted , or the filter is plugged .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
No voltage there with the key on , or while being cranked ?
Moose ,he said he could here it run .
Remember Eric the pump won't run with just the key on ,It must be cranked over to power the pump .------------------------------------------------
Z28 LS1 power 500 +
