I did a search on timing and not sure about the white vs yellow mark on the crank pully. Is the white mark tdc and the yellow pointing to the pin 10 degrees? It is an 89 fi.
When I ground the single conector by the brake booster it only makes the check engine light blink. Does not change the timing. Tryed it before and after I started the car. I dont understand what grounding this does. Does not change the timing.
Am I missing anything? Ground single wire next to brake booster, start car,point gun at crank pully, turn dist untill yellow mark lines up with pointer? White mark? Some people have said they set it at 8 degrees and others at 13. Should it be set at 10?
Sorry if this has been asked a million times. Probably should not be messing with it. Cant help it.
