i'm trying to change my timing belt but i have difficulty to take out the crank pulley. I unscrew the four bolt and the big bolt in the middle . I try too pry it but it only comes out about half an inch but not completly. i'm able to shake it easily with my hand. Wath could i do to remove that pulley.
changing timing belt
What year? The 93 pulleys are different. There are 2 little phillips screws along with the 4 6mm screws that need to be removed depending on what year you have.
crank pulleys can sometimes get hung up on the end of the little key/tooth thing that is used to ensure that everything lines up properly. If your positive you have all the screws out, just get a screwdriver in behind it and tap it with a rubber mallet and it should come loose if the only thing its stuck on is that little key thingNo festiva for me ATM...
Originally posted by TomThe big bolt in the middle I don't think should be removed? should it?
