Is the wire the cargo light goes to a L shaped connector near the pass tail light? Is 1 wire hot and 1 a ground to the special latch in the hatch? there is a harness from the light to the connector? Correct? Thanks.
quick rear cargo hatch light wiring question
Good question, Ive always wondered where the cargo light hooks up. Seen them for sale and would like to have one but dont know where it goes. Havent ever seen one installed.sigpic
I figured it out, the connector is L shaped, and the 1 wire is hot, I couldn't get a good ground so it was showing dead. I have the latch, not installed yet. I made a simple harnes from the light to the connector. I got the light and latch on ebay awhile ago for like $10.69 Shelby GT-350, 351W, 4 spd
97 Jag xk8 vert
06 Mini Cooper S GP
93 Stiva
04 Volvo S80
Where does the light itself mount ?sigpic
Wow, learn something new everyday. Unfortunately I forget two things a dayNeed a couple of cargo lights now.
:evil4:sigpic
I finally installed the hatch latch with the correct wiring, I found that the T-connector on the pass side rear is not the correct wire, there is a longer wire with 2 seperate signle connectors on the end is the correct wiring. The T only has power when the car is on, I don't know what it is supposed to be used for, but it would make an easy amp connect for a sub, if you make a ground wire. If you install a light and don't need it turn on when the hatch is open, you can use the connectors on the light side, and pull the hatch cover off and run a ground to the single wire connector inside the blue wire tape, and just use the light switch when you want light.69 Shelby GT-350, 351W, 4 spd
97 Jag xk8 vert
06 Mini Cooper S GP
93 Stiva
04 Volvo S80
Originally posted by 25HorseplayThe T connector might be for rear window squirter if you don't have one.Ian
