89 festiva fuel injected. One morning tried to start. The solenoid goes clickity clickity but wont turn the starter. My first thought was bad starter. Replaced the starter with solenoid. Started up worked good then the next day it happened again. This has been an ongoing prob for about a month now. It is an intermittent problem, sometimes it happens sometimes it doesn't. I then thought perhaps there was a short in the wire going from the ignition switch to the starter. I completely bypassed the wire and thought I had it figured out then it happens again. Next I replaced the battery cables. Then I thought perhaps the ignition switch was bad so I bypassed it temporarily with no difference. Then I thought perhaps the clutch switch might be the problem. I bypassed it, no change.
I have also replaced the battery.
Any guesses would be appreciated.
