I had to replace my water pump and everything went well.
But when I was removing the lower pulley the crank rotated a about 180 degrees
The belt was still attached to the valve train and tensioned so i don't think this will be a problem, however, my Hayes manual says to prevent the cam from rotating
Can anyone confirm is this is a problem and if so, how do I fix it?
