What is this?
Robert , I am having a hard time naming that , but the one hose goes to the intake plenum and the other goes to the EVAP canister .
I think at a certain RPM the solenoid opens and
Ha ha , just found it ..
The canister contains fuel vapors when the car is not running.
when the engine is running ..The electronic purge control solenoid opens and will burn these vapors .
So it must be RPM related to open, and purge the vapors .
So I would say it is normal to hear it click , that is when it is opening .
That is the hose I use , the one to the intake ..When I give mine a Seafoam treat :lol:------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
It does not say anything about that , did it just start doing , or has it always done it ??
The solenoid itself may be going bad .------------------------------------------------
Z28 LS1 power 500 +
Well I just got back in , I went to see if mine does that ...No it does not click all the time , in that RPM range .
It is just part of the emissions to help burn the vapors that build up when the car is not running , prolly more in the hotter weather .
You should be able to unplug it , see what happens , the clicking will stop , but I am unsure if it will throw the light on of not .
I bet the solenoid is going bad------------------------------------------------
Z28 LS1 power 500 +
