I rly dont wanna get screwed at the dealership, and was thinking of doing it myself. Anyone have any experience with this?
Front wheel bearing.. hard to replace?
Just had a buddy of mine help me with mine....took about an hour or so. All better now. Really wasn't that bad. Need a sacrificial socket for beating and a good flat punch. Plus all the other normal things."FLTG4LIFE" @FINALLEVEL , "PBH"
Archiebold,
I collected the equipment to do it, but found that Festiva Motorsport could not only replace the bearings but the rotors as well for about $200!
So never really did it myself.
Procedure requires a press to disassemble and re-assemble the hub
I was lucky enough to have a set of hubs around to send them so I didn't have to put Big Blue up on blocks for any length of time!
Thanks for adding the your location!
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
A press would have made it easier but not neccessary with a little bit of strong arming from a small sledge and a socket."FLTG4LIFE" @FINALLEVEL , "PBH"
A simple tool for pressing apart:
1) Two pieces of metal 1/4" x 1" x 12" long. Drill a 3/8" hole 1" from one end on each (large enough for the lower balljoint bolt to go through).
2) Gear puller with 2 hooks
With the spindle off and placed with the outside face down,
Place the pieces of metal on each side of the strut mount with the holes lining up with the lower balljoint bolt.
Put the balljoint bolt through the holes and spindle (where it normally goes). Put nut on but do not tighten.
At the strut end put one strut bolt back in the lower hole so that the bars are under it.
The bars should now be parallel to each other and perpendicular to the bearing face.
Take a large socket (I use the one I took the Axel nut off with) and put it open end down, between the two bars so that it lines up with the center of the bearing.
Put a strut bolt into the socket, this will give you something to press against.
Take the gear puller and place the center bolt over the socket/bolt and a hook on each side of the bars.
Now tightening the gear puller should push the hub center out of the inner bearing.
Then use a bearing separator or gear puller to take the outer bearing off the hub center.
Tool to put it back together:
12" threaded rod and several large washers
Now if I only had a picture of this it would be clear as mud.
But if you replace the bearings you will still need to put the correct preload spacer in.
I haven't come up with a simple tool for that yet.~Jeff
1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
2003 Mustang GT 5speed
Originally posted by Gforcefdwhat do you mean festiva motorsports will replace them? Are you talking about new hubs or actually sending in your hubs and having them redone.
I need to do something
Thats not bad at all Dave $80. a side , parts included .
That is a great deal from what I have heard from some people .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Gforcefd,
Read the post closer, nothing was mentioned of FMS replacing the hubs with new ones!
Would have to find my receipt, but think that $200 included return shipping!
Got 40-50,000 miles on them and so far so good!
Originally posted by archiebold80/side isnt bad at all... lets see.. I have one side and at 80/side.....1*80=80??? sweeet 8)sigpic
