pcv valve i think mine is missing or something because i cant find it... any one know where exactly it is and where it plugs into? a pic of it would be great as well any help here would be great.. and sorry for all of the stupid questions.
pcv
ahh the the little black plug with the yellow hose connected to it.. ya know i didnt think that was it.. yep im an idiot...1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
1993 BBF 466cid mustang notch 7.7 ltre
festiva turbo b18 project
2001 BMW 325i
1996 ford F-150 sold
so would this casue any flooding and how do you tell if it is bad?1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
2001 BMW 325i
im not sure it would cause flooding but if you pull it out while the car is running there should be a pretty good suction on the opening.
Mizery wrote: "how do you tell if it is bad?" Shake it and see if it rattles.sigpic
Originally posted by freshtivaMizery wrote: "how do you tell if it is bad?" Shake it and see if it rattles.
But, if you have to get a new one, it shouldn't be too expensive!'93 Blue 5spd 230K(down for clutch and overall maintanence)
well ill try that.. but its not for the festiva its for the b6t motor.1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
2001 BMW 325i
