hay guys , whats up, I was just wondering if the alternator on a 93 b3 auto festi is the same and has the same style conector as an alternator off an 89 FI b6 mazda 323, I have one as a spare and my festi one is starting to suck
alternator interchangeability
compiled from the 323gtx board
RX7 alternators will work in 323s so that means they will work on festivas. The 86-88 alternators are 70 amp,
89-91 are 80amp
and the 93+ are 110amp.
You might need the plug if your plug is different depending on the year. If you stay within the same year range you should be fine. I think mazda switched connectors in 88+ to a round kind and they are all the same on all mazdas. Worst case is you will need to splice in the plug which you can find at the junk yard on pretty much any mazda car.
The rx7 alt swap requires the mazda part # 9980-01-0105 longer bolt. Roughly $6. The bolt is I think 110mm long where as all commercially avvailable i found stopped @ 105mm.
More Info @ http://www.mazda323performance.com/f...ic.php?t=12157It's a good thing you don't read the stickies, you might of learned something.Poverty produces creativity
ya, the plug style is what I was concerned with, its super cold out and i want this to be a painless as possible :lol: , and ya the belt is good and tight, and new so its just a the alternator poopin, plus the alternator has 200 000 kelometers on it now with lots of different amps of various amperage loads through-out that life-span :twisted:
