i just bought a 93 festiva 5 speed. it pops a little when you turn. i think its the steering knuckles and i need to know how hard they are to replace.
steering knuckles
Welcome Smokin Fastiva,
I wouldn't suspect the "steering knuckles" (aka tie rods) first!
More likely the CV joints or lower control arm ball joint!
Is it coming from a specific side or when you make a right or left turn?
How many miles on this one?
PS
Can you edit your profile and add a location so we have some idea were you are?
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
240k will be rolling up shortly! it does it when you turn both ways. im gonna run it until it blows then rebuild it with forged internals and spray the crap out of it just for laughs. im from NC1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
1993 5 speed FI. A/C! muffler delete, 2-5/8" tach, 5% tint, 14" alum. wheels, JVC head unit, 2 MTX 10" subwoofers. 195K
2000 Trans Am 6 speed
1997 HD 1200 sportster
1986 Honda Rebel 250
Thanks for your location!
There are a number of members from NC here!
Maybe someone close enough to lend a hand!
Because it makes the noise when you turn in either direction, I like the CV's for replacement!
Have you checked to see if the CV boots are intact?
Specifically, the outside CV's, nearest the wheels.
Also with 240K on it, I'd check the ball joints.
Do you know how to check the ball joints?
Don't ask how I know, but if the ball joint fails in a turn you have good chance of draining the transmission fluid without removing the transmission drain bolt!
Still possible could be tie rods, but I'd bet on one of the above!
Welcome to the site.
I'm from NC as well. Kenly just off I-95 exit 107.
Where are you located?
Sounds like a CV joint.~Jeff
2003 Mustang GT 5speed
