steering knuckles
  • steering knuckles
    i just bought a 93 festiva 5 speed. it pops a little when you turn. i think its the steering knuckles and i need to know how hard they are to replace.
    1993 5 speed FI. 2-5/8" tach, short throw, muffler delete. SOLD
    1993 5 speed FI. A/C! muffler delete, 2-5/8" tach, 5% tint, 14" alum. wheels, JVC head unit, 2 MTX 10" subwoofers. 195K
    2000 Trans Am 6 speed
    1997 HD 1200 sportster
    1986 Honda Rebel 250
    Welcome Smokin Fastiva,
    I wouldn't suspect the "steering knuckles" (aka tie rods) first!
    More likely the CV joints or lower control arm ball joint!
    Is it coming from a specific side or when you make a right or left turn?
    How many miles on this one?
    PS
    Can you edit your profile and add a location so we have some idea were you are?
    Pu241
      240k will be rolling up shortly! it does it when you turn both ways. im gonna run it until it blows then rebuild it with forged internals and spray the crap out of it just for laughs. im from NC
        Thanks for your location!
        There are a number of members from NC here!
        Maybe someone close enough to lend a hand!
        Because it makes the noise when you turn in either direction, I like the CV's for replacement!
        Have you checked to see if the CV boots are intact?
        Specifically, the outside CV's, nearest the wheels.
        Also with 240K on it, I'd check the ball joints.
        Do you know how to check the ball joints?
        Don't ask how I know, but if the ball joint fails in a turn you have good chance of draining the transmission fluid without removing the transmission drain bolt!
        Still possible could be tie rods, but I'd bet on one of the above!
        Pu241
          CV joint problem it sounds, i agree with PU241. You will usually here clicking noise when you accelerate or turn. Also check those bearings.
            Yep CV's
              I just had the same issue. The Left outer CV boot was torn and the problem went away when I replace the Half Shaft. The part was around $60. Took about half an hour with air tools.
                thanks fellas
                  Welcome to the site.
                  I'm from NC as well. Kenly just off I-95 exit 107.
                  Where are you located?
                  Sounds like a CV joint.
                  ~Jeff
                  1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
                  1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
                  2003 Mustang GT 5speed
                    im off of I-95 exit 180!
