1990 L 1.3L efi, five speed, no a/c
I noticed an electrical switch on my clutch housing today that has one of the two wires off of it. I'm sure it isn't the reverse light switch cause that's on the transaxle case and besides my reverse lights work fine. So then I figured it might be the starter interrupt switch but I still have to depress the clutch to get the car to start. Now I'm not sure what it is. The disconnected wire doesn't seem to affect anything. It think the manual is calling it a fifth gear switch if I'm looking at the right one. Anyone know what the switch is/does that the loose wire goes to ? I can get a pic if it helps. Here tell of a PNP switch (park/neutral/position) but is that on a MTX?
Poverty produces creativity
