Replacing inner tie rods
  • Replacing inner tie rods
    I am replacing the inner tie rods using the pipe wrench method. Which way do I turn the inner tie rod to pop out the pin?
    Thanks
    David
    I will bump this...since it is relevant to my question. Has anyone replaced the inner tie rods in the car (without removing the rack)? How difficult is it?
    Thanks,
    Marty
    91 Festiva L
      I plan on removing a rack from a parts car, just so I can see what i'm doing. Replacing the rods. Then swapping the unit as a hole. That way my car is down for the least amount of time.
        You just start turning the tie-rod end like any other bolt. Righty Tighty - Lefty Loosey. The threads are standard LH threads. Once you get it about 2-3 turns off, the pin will start to push out. There is a flat spot with no threads if you look at the new tie-rod. That's where the pin is when its in. As you loosen the tie-rod the threads then push the pin out. It took me longer to cut the old boots off then it did to replace the tie-rods.
        89 L
          I noticed on ebay someone is selling a pair of inner tie rods but it states they are for 90-93, will they also fit 88-89? also do the inner tie rods come with new boots? I cant get the tie rod ends off so I guess just buying new inner tie rods for my aspire swap would be the best bet unless someone else has any tricks or tips. thanks in advance.
