Strange Tranny Noise
  • Strange Tranny Noise
    I have a 5spd manual in a 91 festiva. If the clutch pedal is all the way out, there is like a rattle or some time of strange noise, but when I press the pedal down about 1/4 to 1/2 inch, the noise stops. I tightened the adjusting nut, but it did the same. I loosed it, but then couldn't get it into gear.
    I forgot if the noise stopped when i loosened it. BUt tightened it back up because i couldn't get it into gear.
    Any clues of what this is?
    there is a new throw-out, so that should eliminiate that.
    Thanks!
    Michael
    Usually that sound indicates a bad throwout bearing, Mine does the same thing, not really a bad thing, just live with it untill you need a new clutch
    1996 Aspire, 2DR 5SPD 185 60 14, Aluminum rims, Mild Stereo system, some neon tubes, 185 000 km not a speck of rust runs like a champ
    B8-ME Swap COMPLETED.
