Can't get crank bolt loosened/Can't get access to it!
  • #16
    Originally posted by freshtiva
    Did you nibble out some of the inner fender ? Put some stuff on in when you put in back in to keep it from backing off on you.
    Put blue Locktite on threads when reinstalling bolt,use a little Antisieze on
    cover bolts
    Renegade-Midwest Festiva Inc.Illinois Chapter
    99 Dodge Caravan SE
    95 Taurus SHO auto 265hp
    94 F150 351W auto (for sale)
    95 Honda 1500 Goldwing SE
    95 Iszuzu Trooper LS
    • #17
      Crank Bolt
      Some more amusing incidents:
      So I'm using this IPA crankstopper that screws down the sparkplug bore and jams against the piston so's the crank won't turn while I'm removing the crank bolt. If anyone has seen them they are a 14mm threaded steel shaft with a hex end and a inset brass plug end that jamholds the piston.
      So's anyway, I've gotten everything done and I'm setting the crank back to TDC to match the cam. I pull out the IPA crankstopper and the inset brass plug is MISSING! Popped out into the cylinder! Glad I noticed it. I imagine if I'd left it in there it would have made a bit of a racket in 'ol No.1. So now I get to pull the head. This would be a great deal more enjoyable if the weather here in Northern Virginia hadn't been between 0F and 29F for the last 2 weeks. (And me working outside on it)
      And to think this job was originally just to replace a waterpump! :lol:
