Oil leak & Smoke
  • Oil leak & Smoke
    My engine is completely caked with oil, i'm assuming this is just the valve cover gasket? cause the oil goes all the way to the top
    The other problem is that when i try to start it, the exhaust is brown, and then blue...
    89SX funtop! Fully loaded!
    RIP 90LX
    Yes looks like vc gasket. If it smokes blue, I would be looking for a B6 to swap in. But that's me.
      about the only way to get that much leaking, is not even fingertight
      Vcover bolts and plugged return drains, and with poor rings
      letting blowby pushing it out.
      BTW, that oil color looks nasty. does the dipstick oil have
      that mocha look too? get steam/vapor from the open oilfill
      when running?
      Anhoo,I second the motion to start looking for a B6
        i third it, better mileage, more power. don't gotta repair all that stuff that is already wrong with it, much better to put a B6 in.
        Find a 323 with a bad tranny or suspension is shot, but has lower km's.
        1.3Liter 4 cylinder FI , OHC, FWD, 3DR, 4ST, Stud. Tires
