I have an 89 festiva Carburated model had several problems trying to get the car on the road (it sat for about a year). I did all the normal stuff: plugs, wires, cap and button, fuel filter, ignition coil (it died during testing), and set timing. The car idled fine but every time you moved the throttle, it died like it wasn't getting gasoline. I figured it was a carb problem and this was later suggested by a few other people. I have disassembled the carb but it was not very dirty ( I have taken a few other carbs apart that were much, much worse) none of the passages seemed to be blocked and I am wondering if this may not have been the problem.
My real question is that I took out the mixture adjustment screw (middle of the back of the carb) I know that I was supposed to measure the number of turns to seated position and record but I did not. I actually thought the screw was some type of vacuum cover (looked like the large vacuum port on the rear of most domestic carbs) anyway, I was wondering if anyone had a good approximate setting for the mixture screw (would give me somewhere to start).
also if anyone has suggestions/comments on other sources for the problem described, please let me know
thank you in advance for any help
