festiva starts and runs, sometimes for 2min before cutting out, other times it will run for an hour, but at some point it WILL stall. Its an 89 auto EFI 150,000 km keep in good cont. Replaced Cap, Rotor, Ign. module, Coil. inspected for loose wiring, ignition switch, fuses. Replaced fuel filter, can hear pump working it delivers fuel, at what pressure I'm not sure. Could something in the distributor itself be wrong? Or would it more likely be a fuel pressure problem, or am i missing the whole point? If Dist, can not find 89 efi will newer models fit, I know wiring is different, is that all.
aaaaaaaaaaaallllllllllllllllllllmost at my wits end
