89 runs then not, then run, then not
  • 89 runs then not, then run, then not
    festiva starts and runs, sometimes for 2min before cutting out, other times it will run for an hour, but at some point it WILL stall. Its an 89 auto EFI 150,000 km keep in good cont. Replaced Cap, Rotor, Ign. module, Coil. inspected for loose wiring, ignition switch, fuses. Replaced fuel filter, can hear pump working it delivers fuel, at what pressure I'm not sure. Could something in the distributor itself be wrong? Or would it more likely be a fuel pressure problem, or am i missing the whole point? If Dist, can not find 89 efi will newer models fit, I know wiring is different, is that all.
    aaaaaaaaaaaallllllllllllllllllllmost at my wits end
    have you checked the in-tank filter?
    91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
    93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
    1981 ford F-100 400000+ miles ? , looks rough - runs good
    1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
      Make sure all your ground wires are tight.
      93 GL modyfied!!!
      :fish:
        Been over it with a fine tooth comb, all are tight, unless some are hiden
          have you checked the fuel filter?
            checked filter, tried to hold finger over end of fuel hose going into intake man. couldn't keep it on, pressure blew it off when pump engaged. don,t know what exact pressure is but i suspect it is enough. am I wrong?
              also connected my own ground to engine, just to be sure bad connection is not the problem. Thanks for your help so far.
