Ok, im trying to get the crankshaft pulley off. Is it ok to rotate the pulley, since i have to set the timing anyways? I dont think i can get if off without rotating it.
Crank shaft pulley
yes
thanks again.
holy @%#&! i just realized that plastic fender thing comes off! Asome! that makes things so much easier to get at! Man, its things like this that makes the festiva soo nice to work on89SX funtop! Fully loaded!
RIP 90LX
use a good screwdriver. I'm assuming they are the original philips screws.
yea, their #2 phlips, the problem is that the engine is about 1/2 inch too high and i cant get a full length screwdriver in there, the angle is too extreme. so im trying to use a stubby screwdriver but its a no go.89SX funtop! Fully loaded!
RIP 90LX
Lower the engine more and rotate the pulley into position. As in the other thread, you don't need to put those back in so if you need to you can grind the heads off.
grind them or drill them... even if you did manage to get them out in one piece (like I did the first time I was working on one) there is a good chance you will lose them (also like I did) and then you'll wonder why you went to all the trouble of getting them out intact anyway
No festiva for me ATM...
Originally posted by oxbrainWhich screws are these? I don't remember any screws on any of my crank pulleys.You gonna race that thing?
Originally posted by stefanwell we got the suckers out, once we lowered the engine they came out easily with an impact driver.
Originally posted by therrisOriginally posted by stefanwell we got the suckers out, once we lowered the engine they came out easily with an impact driver.
Thanks. Got almost all off that I needed. Still trying to get to the water pump screw that's behind the ac compressor and I'll have it off. Getting ready for the new timing belt and water pump. But I've got some stuff that I'll have to start a new thread over. Thanks again for all your help.
