Buying a Replacement Engine Requesting Advise
  • #16
    Buy and sell electronics, cars, fashion apparel, collectibles, sporting goods, digital cameras, baby items, coupons, and everything else on eBay, the world's online marketplace
    Check them out they are alittle pricey but cool look and you don't have to swap bolt pattern, if you want you can get a set of steel rims they are quite a bit cheaper, maybe 29 a piece new.
    get a set of blizzak's and your good to go
    • #17
      Great lead, Wes. I found the tires: Blizzak WS-50 175/70 R13 Winter Tires on Honda stock steel wheels on ebay for $200.
      Currently I am asking the seller what the bolt pattern is. If it is 4 x 4.5 I suppose that would be good.
      Does anyone know if the offset for a Honda Civic 88 is the same as the 1991-92 Festiva?
      • #18
        different bollt patter. Yeah i was those wheels on ebay, you would have to do the aspire brake swap in order for those to work. Yes the back spacing would allow them to fit on a festiva with aspire brakes
